TractorLinks.com
Show Parts for Model:
Re: cam
Zachary Hoyt
09-04-2013 13:52:52
I have a cam from a 47 VAC, you could have it for the cost of postage.
Zach
actionpack
09-06-2013 17:18:50
 Re: cam in reply to Zachary Hoyt, 09-04-2013 13:52:52
ok , I finally got smart enough to get the vt333 number off the cam , is this the same as yours , if it is I would like it , would you happen to know about how much the postage would be , thanks
mEl
09-06-2013 19:08:16
 Re: cam in reply to actionpack, 09-06-2013 17:18:50
Don't know what is being overlooked here but Case only used a 1 3 4 2 firing order and all the cams will work interchangably, the extra round lobe was for engines with an external fuel pump as was used in some applications and has no affect on anything else. As another stated, a 148 cam and I suspect a 159 cam will go right in the VAC and work fine.
actionpack
09-08-2013 15:23:02
 Re: cam in reply to mEl, 09-06-2013 19:08:16
thanks all for jarring my brain , all it was was me and the loose nuts and bolts in my brain , I had the dist wired counter clock wize , and it was suppose to be clock wize , I got a 4 cyl tractor again , yeaaaaaaaaaaaaaaaaaa , thanks for the feed back zack and mEi
actionpack
09-04-2013 18:19:23
I may have 1 , I would like to keep that offer open , but for now I need to find out what vt number the cam is , so I can see if I have it , thanks , if I don't have the right 1 , I will need to take you up on that , my problem is I had 2 cams and I may have installed the wrong cam , the engine is only fireing on number 2 and 3 cyl , on 1 and 4 , I have spark and fuel and compression to them cyl , but its either fireing early or late , any thoughs out there , or do I have the dist off a few teeth
