chloride in 18.4 x 34 tire
Jerry W
Does anyone know how many pounds of calcium chloride will go in a 18.4 x 34 wheel and tire?
Thanks Jerry
Chart
Per the charts already posted:
265 pounds of CaCl per tire for the 3.1 lb/gallon mix x 85 gallons
400 pounds of CaCl per tire for the 5 lb/gallon mix x 80 gallons
Might as well go with the 5 lb mix unless you don't need that much weight, especially if you are in a cold climate and need to use the tractor in winter.
True Fluid is worth about a $1/gal
Call a local tire shop and see if they will make you a deal for your fluid. maybe give you some crdit for future tire purchases?
An 18.4x34 will have close to 80gal at 80% full. With the stem at the very top the fluid will be just below the stem mark to be 80% full
Last time I took out fluid I had to keep it or he wouldn't do it,said no one wanted it,I have 200gal in barrels if anyone wants it.
(quoted from post at 16:04:04 09/01/13) Last time I took out fluid I had to keep it or he wouldn't do it,said no one wanted it,I have 200gal in barrels if anyone wants it.
Every time I get a tractor with it in the back wheels I drain it into the driveway and get rid of it for good! Never liked it never will.
