Pete Speck
New User
Case 970 ser# 8814596 (1977) with Power Shift. Symptoms: Engine starts and runs well, Push in Clutch (inching pedal) does not have much back pressure, and engine does not lurch, Good power steering, PTO operates, Lift Arms move freely up and down, good brake pressure, but it will not move in foreward or reverse direction any gear. All Links to Power Shift Clutch Control appear to be connected and move freely visually under floor plate. All New Hydraulic Fluid and Filters were installed recently - only operated tractor a couple hours since. Need help with checks and tests to further troubleshoot the problem and isolate the root cause. Problem occurred instantly - powered up a hill, stopped, backed and turned off tractor. A couple minutes later I started the engine and the above symptioms were noted. Appreciate any Hints, recommendations and guidance as I'm a tractor novice.
Thanks -- Pete
Thanks -- Pete
