Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Case 970 Will not move any gear has Power Shift
Pete Speck
08-31-2013 14:22:29
Thanks Thad. What are the fix-remove-replace procedures, required actions, tools, gaskets, materials, costs, etc? I've read other forums which suggest the torque limiter failed for similar symptoms. I'm new in the tractor game and have had unfortunate bad luck from the start.
Appreciate any more info. Thanks -- Pete
09-01-2013 03:40:12
 Re: Case 970 Will not move any gear has Power Shift in reply to Pete Speck, 08-31-2013 14:22:29
Basically you have to split the tractor at the rear of the engine. So all hose's line's wiring and fuel lines between the two halves must be disconnected. Tools needed the main thing is some safe jacks or splitting stands. You would need a line up shaft to center the new limiter a belly gasket and limiter. Thad
Pete Speck
09-01-2013 06:38:08
 Re: Case 970 Will not move any gear has Power Shift in reply to Thad, 09-01-2013 03:40:12
Thanks Thad. Sounds like Big effort in the making. Where would one obtain a line up shaft? Can splitting stands be built with heavy lumber or? Are Limiters available from Case or ? Appreciate your feedback. Thanks -- Pete
