970 fuel gauge
the fuel gauge on my 970 case has never worked
since i have had it(around 6 months)
thought i would work on that today, and sofar
i have cleaned all the ends and ground wires
with no help, gauge just sits on empty with switch on and off. i had an extra gauge in the barn and put it on and the gauge jumps to full
when the switch in on. only 3 gal in tank.
i ran a new wire from gauge to sending unit
and it still jumps to full.
what is the problem?
The fuel gauge and the sender need to be in matching pairs. The resistance values are different on some depending on age. There are numbers on them and the right parts guy should be able to fix you up.
