TractorLinks.com
Show Parts for Model:
Re: 830 Diesel Fuel problem
cshess
08-26-2013 04:40:14
It does have a transfer pump between engine an inj pump.Fuel goes through first filter than to transfer pump than to second filter an finally to final filter.With final filter cracked open an buy cranking engine it should blow out air in final filter.If you have t handle turned tight clockwise on top of double filters that should work as you said you have both filters full. That transfer pump if working properly will let you feel pulses on it with your finger. It should developep somewwhere around 15--20 psi if working properly.
cshess
08-26-2013 04:44:04
 Re: 830 Diesel Fuel problem in reply to cshess, 08-26-2013 04:40:14
Forget !I would remove line going to fiirst filter an make sure there is a good supply of fuel .Tank an tank outlet could be starving rest of system.
