I have a 67 Case 830 CK (has gas engine so I'm told it is actually an 840?).
Anyway I have two questions. First, when I shut the tractor off after using it for a longer period of time (at least 30 minutes) it will run on a little bit and then blow air out the intake. The glass bowl (on the intake tube at front of tractor) has been getting dirty so I decided to remove it and clean it and when I look down the tube I see liquid in the bottom. It appears to be water but unsure how it got there. I have no leaks in the coolant system and don't see how coolant could get there anyway. I assume this is not normal so how can I drain this without taking apart the entire front?
Second question. I need a new radiator cap as mine is getting old and worn out and I either need to know where to find a correct replacement or can someone tell me what pressure the cap is so I can go that route to finding a replacement?
I have a manual in PDF format for the tractor but it is about 600 pages (includes diesel and LP as well as the gas) so I skimmed and seen nothing relating to either of my needs and google was a waste of time.
Hope someone can point me in the right direction here.
