Hi,
We have a Case 4230 which seams to be leaking diesel from around one of the injectors. There appears to be a seal/o-ring around each injector where it enters the block. The other seals are all below the block surface but this one is protruding slightly. I am assuming this is the cause of the leak. If this is so, could someone explain how I could fix this problem. Is it just a matter if pushing it back down?
Thanks
Thanks
