1070 clutch noise
timbernt
The main job for my 1070 is to pull a 9 ft Kuhn disc mower. Have about 5 hours mowing left, but this evening it developed a growl when "clutch" pedal depressed. Do I dare use it to finish mowing or will the 2094 have to it all? I assume it is the needle throwout bearing? Shifts fine between gears and powershift.
Is your 1070 a 8sp or a powershift model? If its a powershift model it sounds like the sun gear or one of the planetaries in the powershift unit is chipped which will require the tractor to be split and the powershift pulled and fixed.
