Case 230 Baler Needles
TriTownTB
I broke the left side needle on my Case 230 baler. Does anyone happen to have one of these or a set laying around? Or where could I get a set? It appears that the needles were broke and welded before I got the baler. So far its worked great the 2 years I"ve had it and I want to get it fixed and keep baling! Thank you for the help.
Weld it again, not hard to do. Just take the other off and lay them together to keep the shape right. Don't forget to find out why it broke so it doesn't happen again.
You say you bought it a couple years ago. PLEASE, do what I didn't. Change out ALL the roller chains on your bailer. That's WAAAAAAAAAAAAAAAAY cheaper than changing out the needles, as I found out on my 1060 140W. ALSO, IF your tie mech has a spring that closes a clutch fog against a pin. CHANGE OUT THAT SPRING. That will save you having to retime the bailer, PLUS finding replacement parts for the tie mech head.
