Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Need a throttle shaft
Firemanjohn
07-15-2013 17:30:35
I hate to keep bothering everyone with non-case issues, but this is the best forum I have found and all of you guys are so helpful. I spoke of an old flathead mack I was restoring and came in need of a throttle shaft today. It actually is for he governor, which uses butterflies like the carb and is under the carb. It is 9/32 brass shaft and has a slot machined into the middle, not just one side, for the butterfly. The butterfly is 1 7/16" across and the shaft only needs to be about 2 1/2" to 3" long. I know it is not case, but perhaps the description rings a bell with something on a shelf that I can modify. My shaft has the linkage clamped on so I just need a donor. Thank you everyone for the best forum going
DKase
07-15-2013 18:00:58
 Re: Need a throttle shaft in reply to Firemanjohn, 07-15-2013 17:30:35
All my old trucks had them removed years ago. Why do you feel you need it? You do have a foot that lifts don't you?
Firemanjohn
07-15-2013 18:28:32
 Re: Need a throttle shaft in reply to DKase, 07-15-2013 18:00:58
Haven't got enough experience with this kind of a motor to figure out if I need it lol. It is a strange set up that is for sure. Just wanted to fix it because it was there. Is it something that can be eliminated?
DKase
07-15-2013 19:45:30
 Re: Need a throttle shaft in reply to Firemanjohn, 07-15-2013 18:28:32
Basically what it does is close the air off when the engine gets to governed speed so the door knob driving does not over rev the engine.
