TractorLinks.com
Show Parts for Model:
Re: Model D not running good under load
oldproudvet
07-14-2013 07:41:58
The fuel systems are very basic. Weak spark issues will send you chasing carb overhauls for ever. Under load, the combustion chamber is full of fuel and air, it takes a much hotter spark to jump a gap then under light or no load conditions. Plugs could be an issue by I'd bet the farm on a weak mag. Over the years I've replaced all my magnetos with distributers and 12v alternators and have very reliable older tractors
bosco1
07-14-2013 10:13:40
 Re: Model D not running good under load in reply to oldproudvet, 07-14-2013 07:41:58
thanks for all the suggestions! This tractor had the same problem before I rebuild a carburetor. so I think I will chase after the spark.which direction do I go for 12 volt conversion if I do so.? the serial number on my model D's is 5003699 what year would that be?
Case Nutty 1660
07-14-2013 09:04:28
I have seen this same condition as well worked on a carb till I was blue in the face finally pulled another carb know to be good and found it was a mag problem cnt
