Hi. I"m needing help. I just purchased an old case 530 back hoe. I"m trying to figure out if it has a clutch or a torque converter. Also where do i add hydraulic fluid? I got it started but it will not move when you put it in gear. The loader went up slowly then blew a hose. I have replaced the hose and need to refill the hydraulic system. There are 2 levers (one on each side of the trans) I"m not sure what they do, and one on the left side of the steering wheel. My model # is G530 TC and ID # is 8245925. Does anyone have any info on this? What manual do I need and can I find it here? Thank you for any and all help!
Kevin
Kevin
