TractorLinks.com
Show Parts for Model:
Re: g530 tc
Case Nutty 1660
07-09-2013 18:36:29
here is a scan on how the Case-O-Matic direct drive lever is used
Kevin.530
07-09-2013 18:57:59
 Re: g530 tc in reply to Case Nutty 1660, 07-09-2013 18:36:29
Thank you! So with that lever will it start moving when the clutch is let out? If the hydraulic system is low will it make the tractor not move?
Case Nutty 1660
07-09-2013 19:14:09
 Re: g530 tc in reply to Kevin.530, 07-09-2013 18:57:59
yes the tractor will not move if the torque convertor is low on oil, this scan is from 570 book but fill point is the same on a 530CK
Kevin.530
07-09-2013 19:30:26
 Re: g530 tc in reply to Case Nutty 1660, 07-09-2013 19:14:09
Is that checked running or dead? Does the loader and back hoe share the same hydraulic reservoir? Does it use a special fluid or will regular hydraulic fluid work?
Case Nutty 1660
07-09-2013 20:02:23
 Re: g530 tc in reply to Kevin.530, 07-09-2013 19:30:26
check it right after shutdown while hot, it will read high on the stick when cold and engine off on the oil they called for Case TCH fluid back in the day today I run Case Hy-Tran Ultra fluid in the hyd system and torque convertor it does cost more but to me its worth it, you can also run a equivalent
Kevin.530
07-09-2013 20:17:14
 Re: g530 tc in reply to Case Nutty 1660, 07-09-2013 20:02:23
Thank you for all your help. Im going to work on it more tomorrow. I'll prob be back with more questions.
