Is it just me??!!
John Saeli
I can"t find an on-line parts book for the 200B tractor on the CASE sight. They show a CASE 200 Rake & the 200 Baler, but no tractor. All kinds of IH $#&?.
Tom: I needed to look up parts for the 210B steering cyl. which are not in my 200B Book. Found them in my 300B book. If there was a way to get into the inner-sanctum of CASE & say "Look here you stupid sons-a-bytches, fix that site!!" they probably would, but I don't know how to get into the inner sanctum anymore.
I have used the parts site to find parts I need and yes its not as easy to use as before but that have had all the parts I looked for both caseIH and IH machines I guess just maybe kept the more popular parts on here just saying check with you local dealer he might be able to help.
John I have a ctlinder with valve that broke the rod (shaft) when a spindle broke ( I got it for parts). What can be bought for those steering systems part wise?
It is a wreck. A few weeks ago the 1194 was missing...but appears to be back after a hiatus.
One of the 70 series tractors I was looking up the other day only had about 1/2 the systems once you got to the right tractor.
The 300-300B PS cylinder was made by Bendix. The same cylinder was also used on 55-58 Ford & 54-56 Mercury.
The spool seal kit is Ford p/n B5A-3318-A. Another number stamped on the package 13875 may be a cross-ref nr.
The kit includes bushings #15 & 16 and seals 11 & 12. In the inset box for Case spool seal kit #10 is a common nylock nut, #13 & 14 are common o-rings, #11 & 12 are the spool seals. The aluminum bushings are a wear part and should be replaced with the seals if any wear or the seals may not last long.
I"ve bought the Ford kit on Ebay but it has been a couple of years. May be still available from Ford?
Joe
Parts Book doesn't show that CASE offered the Rod separate. They made you buy the whole cyl. It is currently priced @ $1075.00, but may not be available. At that price, they probably can't keep them on the shelves.
