TractorLinks.com
Show Parts for Model:
Re: Is it just me??!!
Case Nutty 1660
07-09-2013 08:37:39
what are you needing John I have a 200B parts book, will be back later to check here if you need some scanned
John Saeli
07-09-2013 09:06:01
 Re: Is it just me??!! in reply to Case Nutty 1660, 07-09-2013 08:37:39
Tom: I needed to look up parts for the 210B steering cyl. which are not in my 200B Book. Found them in my 300B book. If there was a way to get into the inner-sanctum of CASE & say "Look here you stupid sons-a-bytches, fix that site!!" they probably would, but I don't know how to get into the inner sanctum anymore.
oldmisterbill
07-09-2013 13:45:23
 Re: Is it just me??!! in reply to John Saeli, 07-09-2013 09:06:01
John I have a ctlinder with valve that broke the rod (shaft) when a spindle broke ( I got it for parts). What can be bought for those steering systems part wise?
John Saeli
07-10-2013 06:11:51
 Re: Is it just me??!! in reply to oldmisterbill, 07-09-2013 13:45:23
Parts Book doesn't show that CASE offered the Rod separate. They made you buy the whole cyl. It is currently priced @ $1075.00, but may not be available. At that price, they probably can't keep them on the shelves.
Joe (Wa)
07-09-2013 17:28:32
The 300-300B PS cylinder was made by Bendix. The same cylinder was also used on 55-58 Ford & 54-56 Mercury.
The spool seal kit is Ford p/n B5A-3318-A. Another number stamped on the package 13875 may be a cross-ref nr.
The kit includes bushings #15 & 16 and seals 11 & 12. In the inset box for Case spool seal kit #10 is a common nylock nut, #13 & 14 are common o-rings, #11 & 12 are the spool seals. The aluminum bushings are a wear part and should be replaced with the seals if any wear or the seals may not last long.
I"ve bought the Ford kit on Ebay but it has been a couple of years. May be still available from Ford?
Joe
John Saeli
07-09-2013 18:54:53
 Re: Is it just me??!! in reply to Joe (Wa), 07-09-2013 17:28:32
Parts still available frm CASE.
