1070 shift/hydraulic levers shop manual?
oldproudvet
Building on the post below, I had a conversation with a cow on Friday and one sprained ankle and twisted knee later I'm sitting the weekend out. I recently brought home a low houred late 1070 with a couple of control lever issues. In the power shift troubleshooting section it reads "shifter linkage bound/misadjusted cable bent, siezed or misadjusted" or something like that. I've paged thru the entire manual several times and can find NO mention or even pic to help with this. One page shows the PTO engagement lever, but from the wheel side, not the cab side. There must be something in there, is there not? When pages can be spent on valve seat angles that every 8th grade shop kid knows I'm puzzled by this or is it my own stupidity. Thanks
proud vet ,it never ceases to amaze me why the halethe books go into so much obvious detail to install a valve cover ,,, but very little detail and DARK pix for adjustin a pto clutch//// ,take the shifting cover up ,spray wd -40 all over every moving shifting part and linkage , my 1070 was so damstiff when I got it , I almost traded it off ,and would had too , but couldn't pull the deal ,oiling the shifting shaft under the platform helped it a bunch too/// EXCEPT use sparingly oil FOR THROTLE FRICTION PLATE AND 3 PT LIFT ,,,you do that and apply grease on those joints and it will work like new ,,, why the hakle case did not put grease zerks on these shiftin collars is beyond me .. it seems sorta stupid ??,,
