Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 730CK PTO clutch???
Adirondack case guy
07-05-2013 16:58:14
Try this first. If that doesn't work we will walk you through removung the rear tranny housing, without removing too much of the 3pt.
07-06-2013 09:18:59
 Re: 730CK PTO clutch??? in reply to Adirondack case guy, 07-05-2013 16:58:14
looked thru the hole , and found some loose parts.. :( ...gonna have to limp it thru 2 ac of hay baling and tear it down...anyone have a pto clutch assembly for a late model 730/830???
07-06-2013 15:20:13
 Re: 730CK PTO clutch??? in reply to shawnspeed3, 07-06-2013 09:18:59
They're out there. I got mine from John Saeli. Wasn't too expensive either...slim
07-06-2013 15:59:26
 Re: 730CK PTO clutch??? in reply to denverslim, 07-06-2013 15:20:13
Funny thing...went to a local wheeler dealer guy that has a pretty clean 1070..6300 hours for 6500 bucks...and I notice another older case in the back...730 CK diesel, with the case o matic...has a bad rod supposedly...he wants to sell the whole now I am going to sell a few other items to get this tractor, to fix I have really been wanting to switch over to a diesel...and the gas tractor can become a parts machine..maybee...unless I can find a rod , and the crank is not hurt....Shawn
07-21-2013 06:44:33
 Re: 730CK PTO clutch??? in reply to shawnspeed3, 07-06-2013 15:59:26
OK ..a little update...still working on purchasing the diesel :D the gasser PTO assembly removed, and the previous owner must have overhauled the PTO, cause everything looks new...only problem is they did not stake the nuts on the links between the 2 halves of the PTO clutch :oops: guessed it , one of the links got mangled, nut & bolt, setting in the bottom of the diff, unharmed...I straitened out the links, will be staking ALL the nuts in place, and re-assembling the tractor...Thanks for the help...Shawn
