TractorLinks.com
Show Parts for Model:
Re: Db case 885 pto clutch
RGMartin
07-05-2013 12:18:32
To adjust take off the bottom or side plate depending on the tractor. You loosen the jam nuts, and adjust the set screws till there is .060" to .070" clearance between the end of the screw and the casting. Mark each one as you do it. Then turn the engine over till you get to the next one.
There is also a chance that the adjustment is fine, but the intermediate plate, or PTO clutch plate are stuck. Easy way to fix this is put on a Tiller or brush hog, get it running by starting with it in gear, get it going to where you are really working the engine, then push in the clutch all the way.
Nick 4066
07-06-2013 07:46:41
 Re: Db case 885 pto clutch in reply to RGMartin, 07-05-2013 12:18:32
There is a plate on brake pedal side that I took off and could see in the clutch area but I coulndnt identify the three adjusting screws.
richardinnz
07-06-2013 23:22:55
 Re: Db case 885 pto clutch in reply to Nick 4066, 07-06-2013 07:46:41
You need to be right underneath the tractor, the plate (plastic if memory serves) is about 2 1/2 X 3". The nuts and screws are in the cover its self, not on the release fingers like a Massey.
joe stewart
07-05-2013 16:20:05
I have the 885 instruction manual in pdf format. I can email it to you. It will tell you how to adjust clutch (with diagrams). PM me your email address.
Nick 406
07-05-2013 23:39:36
 Re: Db case 885 pto clutch in reply to joe stewart, 07-05-2013 16:20:05
How do I pm an email.
joe stewart
07-06-2013 03:04:13
 Re: Db case 885 pto clutch in reply to Nick 406, 07-05-2013 23:39:36
Click on my "handle" or username. A box will pop up. Send me a valid email address and I'll send you the David Brown instruction book for the 880, 885 or 990 (I have all three!)
paul walsworth
07-31-2013 17:19:01
 Re: Db case 885 pto clutch in reply to joe stewart, 07-06-2013 03:04:13
Sir,
I need the information about the clutch on a Case 885. I have the same problem as everyone is describing, otherwise it is a great old tractor.
Thanks, paul W.
joe stewart
07-06-2013 03:07:30
Correction / Revision: To send me an email, click on the "send email" tab in lower right of this posting
ldcravey
07-17-2013 20:08:29
 Re: Db case 885 pto clutch in reply to joe stewart, 07-06-2013 03:07:30
Joe, your posting has "no email" displayed in the lower right corner. I am interested in the PDF of the DB/Case 885 Operators Manual.
joe stewart
07-18-2013 03:25:12
 Re: Db case 885 pto clutch in reply to ldcravey, 07-17-2013 20:08:29
Click on my handle at the top of this message in order to send me a private mail. Where it says "Posted by joe stewart". I"ll send you the manual. Thanks
