Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Case 1070 Fuel issue.Help
Dieseltech
07-05-2013 04:35:29
How many hours does the pump have? High hours use may have the plunger control sleeves worn badly so equal delivery between cylinders cannot be held, cam bearing wear causing end float will cause governor trouble too. If low hours these should be OK. There is a sensitivety adjustment inside governor cover that can be adjusted also. Tractors usually set 8-10%, combines 5-7%, gensets 3%. If someone set it too close on regulation it will surge, and resetting low idle and bumper spring may not remove it completely.
jon f mn
07-05-2013 09:44:50
 Re: Case 1070 Fuel issue.Help in reply to Dieseltech, 07-05-2013 04:35:29
I was wondering after my last post if the heat from the fire could have damaged the gov. spring and would that cause this too?
Dieseltech
07-05-2013 11:00:02
 Re: Case 1070 Fuel issue.Help in reply to jon f mn, 07-05-2013 09:44:50
Fire may have caused bumper spring damage, depending on how hot it became. Main governor spring in Bosch RSV governor is very heavy, aluminum cover would melt first. At least that's what I have seen in the past, with combine pumps anyway that were torched.
