TractorLinks.com
Show Parts for Model:
Re: 970 case problems
jesse keller
07-02-2013 19:54:51
Yes it is a 1970 is this the pump right above the pto
case trader
07-03-2013 04:04:55
 Re: 970 case problems in reply to jesse keller, 07-02-2013 19:54:51
I'll agree w/Rod the early ones drove from the limiter the later ones from the flywheel,i guess you could pull the pump off and see if the shaft turns,(if the limiter was broke could still turn w/no load)
1370rod
07-02-2013 20:27:14
Start the tractor, without pushing in the clutch shift the 4 speed gears in gear. If there is no gear grinding what so ever in any gear nothing is trying to turn inside the trans. Chances are the hub is broke loose on the torque limiter. Tractor will need to be split behind the engine to correct the problem. Rod.
