400B 500 motor ??
511 and 600 caseomatics have a 164 ci engine ,,the 411 has a 159,,and the 311 is a 148. never done it , but I would bet a dollar to a donut that they would swap out ,, others will chime in , if I need corrected,,.Thad are you out there ?
my thoughts are they will bolt right in ,, one thing though a 411 had the same engine as the 300 series a 148 only the 530 had the 159 as far as tractors go cnt
The 300/300B and 411B 148 cid engines are pretty much the same except the block in way of the pan and starter mounting.
300/300B starter bolts to the torque tube. The 400B starter bolts to the block (seal the COM?).
There is probably some way to get around that.
Joe
