430 torque specs
farmboyWI
Does anyone know the torque spec for the wheel to hub bolts and the hub to axle bolts on the rear axle? Going to replace a leaking oil seal. Thanks!
My tech manual does not have the spec for the steel wheel to hub torque but list the hub to axle. The book said "tighten the bolts evenly until slight resistance is felt, tighten bolts to 70 to 80 lbs, then 150 to 160lbs, then to 270 to 320 lbs." They want it done in three steps.
