jon f mn
Worked on the 1160 today. It seems to run well. put an electric fuel pump on, then found that the problem was a stuck float needle. LOL oh well. Also fixed the mufflers and put the rubber bushings in for the shoe. Then took some shims out of the walker wood blocks. That is not a job for the faint of heart. I may have used some inapropriate words while doing that. Also found that the shaft in the clutch housing was seized. Had to get the little woman to help with that. I tied a strap to the lever and pulled it back with a bar and then the wife would push it down. Took a while workin it back and forth and sprayin with lube but at least she moves now. Here's a couple of videos of it running.
http://www.youtube.com/watch?v=WZhY2eFHx3Q&feature=youtu.be
http://www.youtube.com/watch?v=ZWB5gD6_-SM&feature=youtu.be
