check out a picture of these tires im looking at
im needing a set of tires for 970 wish i could afford new but cant really afford them right now. found these useds ones i emailed him and asked if they was weather cracked and if that was a hole in that one tire and all he said was they wasnt weathercracked that bad and was removed bout 2 weeks ago. does it look like a hole in that one tire to yall? wouldnt be that big all deal if i could put boot in it long as its not rotten they would serve the purpose for what im goin to use it for (pulling baler).
I guess if it was me I would also like ta know alittle history ( what they did)?? but the price would be the real factor for used tires. With the price of new ones and china tire..... Your better off buy'en 60% to 80% there's alot of good tires out there. Jus my 11 cents worth.
Looks like the sidewall to face are cracking, once you pump them up they will look worse. If you could find an old set of firestone field and road tires they can look bad and still run a long time. Goodyear and co-op tires seem to crack open and will pinch the tube. I have run all brands and firesones seem to be the hardest to change but last the longest.
Where are you located in tn? I to live in tn and my dad has a good used set of 18.4/ 34 firestone radials 70% or better forsale.
