Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Case 680C
Case Nutty 1660
06-24-2013 13:50:20
its been 40 plus years since I serviced a 680C,, it will have a trans filter not sure if it is by the trans or mounted by the engine, is the oil foamy when it quits? or still milky/dirty? sounds like it may be covering the suction to the pump and you are loosing clutch pressure, again it has been many years but does it have a pan on the shuttle you can remove and clean/check the screen
Philip Schemanski
06-27-2013 11:10:20
 Re: Case 680C in reply to Case Nutty 1660, 06-24-2013 13:50:20
It doesn't have a pan but it does have an access plate bolted on the right side of the transmission. I made a quick look and didn't see any filter, I will look better this week end and I didn't look at the fluid. I will do that this week end also. Is there a way or a fluid to flush the transmission?
Thank you for the help.
