torquing head bolts on a 995.
do you torque the bolts with oil or leave them dry?one shop manual says 90 lbs and the owners manual says 100 lbs.anyone have suggestions?
30 then 60 then 90 or 100 in proper order, DRY and Clean
The 100 figure I think was used where they weren't re-torquing them after running it.
thanks i torqued at 100 dry. the bad part is 5 head bolts are blocked by the injecters.so its a big job to retorque after a run.
