Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 730 Steering Bushings
Bruce from Can.
06-07-2013 02:50:38
When I did mine, I just used a brass bushing, and put in two grease zerks on the cast pedestel. Bruce
06-07-2013 08:08:00
 Re: 730 Steering Bushings in reply to Bruce from Can., 06-07-2013 02:50:38
that's what I did on my 1030, bought bushings from a supply house for a fraction of CNH's price, then drilled the housing for grease fittings. Also, if you need to replace the bearing balls at the shaft rides in, I used sealed ball bearings with a locking collar. You have to grind the inside of the bearing housing a little bit with a die grinder so they fit properly but they work nice.
06-07-2013 19:37:34
 Re: 730 Steering Bushings in reply to 1031D, 06-07-2013 08:08:00
Thanks for all the replies. I guess I know a little more about the job ahead now. I might just put it off til winter when the tractor is not in use.
06-07-2013 06:18:04
I like the idea of the greaseable brass bushings. I expect the parts from CIH will be outrageously expensive like they always are. Hope I dont have to pull the steering wheel as it is already cracked.
Gene Dotson
06-07-2013 07:22:46
 Re: 730 Steering Bushings in reply to rusty6, 06-07-2013 06:18:04
The bad news is that you will have to pull the steering wheel. The lower part of the shaft is integral with the u-joint yoke. Unbolt the top section casting and lift off the shaft. Bushings are in this casting.
