Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 2090 quit moving
06-06-2013 20:05:03
The tractor will quit moving if you lost your hydraulics. If the the steering is gone also the problem would more than likely be in the pump drive system. If its the limiter your hydraulics will still work and you will be able to shift the 4 speed in gear without depressing the clutch pedal with the engine running and there will be no gear grinding. Rod.
Mr hillbilly
06-07-2013 07:57:35
 Re: 2090 quit moving in reply to 1370rod, 06-06-2013 20:05:03
Thanks for the info guys I'm going to check out the tractor this weekend was wondering if I pull drain plug can I use my video scope and see the center of torque limiter or not
06-06-2013 20:16:23
Also on 2090's there's a ball brg on the front of the 4 speed trans input shaft that goes out which allows the shaft to drop down causing the drive gears not to mesh. That to will cause the tractors to stop moving. Rod.
