Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 1070 pto pressure
06-05-2013 11:16:05
If your trans press gauge runs with the needle in the green chances are your pto press is ok. However check the control
linkage and make sure when the PTO lever is in the engaged position, that the spool in the valve has been moved all the way.
06-05-2013 11:29:01
 Re: 1070 pto pressure in reply to 1370rod, 06-05-2013 11:16:05
I also forgot to mention if you have slipped the PTO clutch a lot the disc's are more than likely damaged already. With the unit off the tractor you can apply air pressure in the pressure line fitting of the PTO and listen for any obvious leaks in it. When replacing the clutch's I prefer to use the A33012 disc's. Rod.
