TractorLinks.com
Show Parts for Model:
Case 1170 hydraulic disconnects and dust covers
fastline
06-04-2013 11:06:09
I am trying to sort through the maze of hydro fittings. I am pretty sure this tractor needs to be converted over but have not tried a fitting in it yet. All implements are the pioneer ISO type with ball end. The female disconnects on tractor are cone shaped on the outside and look original. If that is the case, can I be certain they need to be replaced with the standard style? Of course they are REALLY on there so I will have to take bigger tools over to get them off.
As well, it seems no one knows what dust covers are. All the fittings on this stuff are nasty and I cannot stand it. Oil contamination, coupler damage, leakage, etc. As well, I would think dust plugs would be cheap, but NO, 8-10 bucks each! Is there a cheaper way? I know our old M&Ms back in the day had those nice metal threaded caps. SLICK!
fastline
06-07-2013 11:54:41
 Re: Case 1170 hydraulic disconnects and dust covers in reply to fastline, 06-04-2013 11:06:09
Parker PN 4080-4, 25 bucks each, problem solved. They are certainly slick.
4435
06-07-2013 06:45:51
Fastline, what is the part # on the parker fitting? I have a place not terribly far away that deals parker fittings. Tom
fastline
06-07-2013 07:15:47
 Re: Case 1170 hydraulic disconnects and dust covers in reply to 4435, 06-07-2013 06:45:51
4435 said: (quoted from post at 06:45:51 06/07/13) Fastline, what is the part # on the parker fitting? I have a place not terribly far away that deals parker fittings. Tom
Tom I am not yet sure what I am going to do here but have only a small amount of time to figure it out.
I did look up the adapter PN posted by John S and what I found was an adapter that has 7/8x18 male thread to 1/2NPT female thread so you can have a hose made and keep the factory couplers. At this point, I want to throw those stupid things as far as I can. I would also consider just getting the correct male (nipple) ends for the equipment to get me going for now if I can determine what style the case is.
Anyone? John, Tom? I would need the male ends with femal 1/2" NPT
This post was edited by fastline at 07:16:48 06/07/13.
fastline
06-06-2013 13:52:23
Well.....That was a complete waste of time at the hydro store. One thought they had it all figured out until I walked in the door...
I called another and about fell over when I just asked how much to make a Male Case/Female ISO coupler adapter. He said about 150 each. The couplers cost about 80 bucks each. His must be made of gold because I can find Parker 4000 stuff for about 20 bucks.
Case Nutty 1660
06-07-2013 05:58:57
 Re: Case 1170 hydraulic disconnects and dust covers in reply to fastline, 06-06-2013 13:52:23
read John S post below he has the adaptors and at a reasonable price too
fastline
06-05-2013 13:31:47
Going to visit my local hydro shop now. I guess they have the right coupler for this that converts the odd ball thread on the Case hose to the Pioneer. They called it a 5/8 straight. Price was stellar as well and I just realized it is the same company we buy all our endmills from....Who knew....
Mopar66701
06-05-2013 15:07:32
 Re: Case 1170 hydraulic disconnects and dust covers in reply to fastline, 06-05-2013 13:31:47
Now hope the hoses never go bad and you are golden
fastline
06-05-2013 11:48:26
So are the threaded ports on the remote valve housing NPT threads or are they special too?
I was considering going to the farm store to see if they have 4 short hoses to get that going.
Case Nutty 1660
06-05-2013 12:19:34
 Re: Case 1170 hydraulic disconnects and dust covers in reply to fastline, 06-05-2013 11:48:26
the ports at the remote valve are "JIC" thread with a 90 degree fittings
Ron Sa
06-05-2013 07:00:07
On my 1170, I use adapters. Works fine. Keeps the tractor original and uses the original dust covers. I keep the adapters where I know where they are and they are kept clean.
Agri King
06-05-2013 04:37:38
The best thing you can do is buy 4 new hoses from Case, for a late 1175 (etc). Make sure the coupler end of the hose is pipe thread put 4 new Pioneer couplers on them. BUT, I bet your tractor has the swivel fittings on the remote valve. The new hoses will be tapered flare. Go to the salvage yard and get 4 tapered flare remote valve fittings, And the springs behind them, I have seen different lenght springs with different fittings. After all this screwing around and $400-$500 you're done!
Mopar66701
06-05-2013 06:08:02
 Re: Case 1170 hydraulic disconnects and dust covers in reply to Agri King, 06-05-2013 04:37:38
When i encounter those half tubing half hose and they arent cheap and easy i use a compression fitting to reuse the special tubing half. I like to make everything to where if the hose ever fails again all i need to do is go get a hose with male pipe threads on each end.
Mopar66701
06-04-2013 20:59:18
I put pioneer iso on everything. New hoses where required. Same thing on all implements. Also use the rubber dust plugs. Usually hit tractor supply for that stuff. Not too high. About $4 for a pair of dust plugs. I hope i didnt just jinx myself again
D-C-741
06-04-2013 20:37:05
We Change our tractors over to 90 series style & throw the old style ends in the corner shelf /they have no value ,on newer tractors =all the newer Equipment uses Pioneer ends.just changed over 730/2 870 s /830 & 1070 yellow /The Hoses are replaced when we change them over.
John Saeli
06-05-2013 18:44:51
 Re: Case 1170 hydraulic disconnects and dust covers in reply to D-C-741, 06-04-2013 20:37:05
Hey DC! You're correct, no value, but I will pay you for those old ends. Send them to me. BTW, how's "Blue Eyes" doing?
dlwin
06-04-2013 18:58:52
If you use the adaptors make sure you disconnect from the tractor as the adaptors have been known to leak and empty the hydraulic system in minutes.
fastline
06-04-2013 14:37:22
Of course the thread would be different!!! What a day....
So, where can I get adapters? This is going to get expensive, I can feel it now... Does anyone know what type of coupler the Case is if I wanted to try and find male fittings for my hoses? I don't think that is a good idea since the equipment would then be married to that tractor. Sounds like I need male coupler ends with male thread, threaded into female couplers with female thread. What fun.
After all is said and done, those hoses on the tractor will start leaking....lol
Case Nutty 1660
06-04-2013 15:08:46
 Re: Case 1170 hydraulic disconnects and dust covers in reply to fastline, 06-04-2013 14:37:22
this would be the cheapest way to go this is a Pioneer tip for J.I. Case couplers with 1/2" female pipe thread
Case Nutty 1660
06-04-2013 14:01:18
here is a shot (first pic) of Case style couplers with the adaptors and a shot of another way you can go is to buy coupler adaptors that allow you to use the original couplers but still plug into the Pioneer style as well, these are on my 1470
Rgmartin
06-04-2013 13:26:53
You are going to need new hoses too. The Case couplers used an oddball thread.
Case Nutty 1660
06-04-2013 13:30:08
 Re: Case 1170 hydraulic disconnects and dust covers in reply to Rgmartin, 06-04-2013 13:26:53
correct, Case used to sell a adaptor back to pipe thread, the last ones I bought was 25.00 or better each I have some around I will try to post a pic
John Saeli
06-05-2013 18:42:30
 Re: Case 1170 hydraulic disconnects and dust covers in reply to Case Nutty 1660, 06-04-2013 13:30:08
Tom: A27744 Adapter. CASE List is $16.59. We keep them in stock.
Case Nutty 1660
06-05-2013 19:58:51
 Re: Case 1170 hydraulic disconnects and dust covers in reply to John Saeli, 06-05-2013 18:42:30
amazing they still have them and that is cheaper than I remember not that bad
fastline
06-04-2013 13:14:29
I pulled the female coupler off the tractor and mated it to an end on an implement. The female coupler is too big in diam.
So....I am shopping for ISO 5675? I was confused if that designation included both the pointed male tip and the ball tip? All mine have the ball tips.
brokengun
06-04-2013 12:49:47
I thought Case 70 series were all ISO fittings.
I know my 1370 accepts male ISO ends.
As far as dust covers/plugs I pay around $4 for mine from shoup.
Case Nutty 1660
06-04-2013 13:00:48
 Re: Case 1170 hydraulic disconnects and dust covers in reply to brokengun, 06-04-2013 12:49:47
the "ISO" couplers were made standard on "70" series tractors starting in about 1974, BUT you could still order the Case style until the end of "70" series production I have a 1977 970 that has them from the factory cnt
