Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Case 220 Electrical issue
David Shirk
05-20-2013 08:54:50
Thanks for your input. I do get the starter to run "in place" by jumping the two terminals on the solenoid. But the engine won't fire up. Trying to reason it out, if the solenoid is bad, it still should start by jumping when the ignition is turned on...shouldn't it? Perhaps it is a ground. I'll keep searching.
Case Nutty 1660
05-20-2013 11:51:08
 Re: Case 220 Electrical issue in reply to David Shirk, 05-20-2013 08:54:50
David, that is why I would start at the ign switch and see if it has power to it and thru it, yes with the key on and by jumping across the solinoid it should ave started, my guess is that you do not have power to the points and since you lost starter enguagement at the same time that is why I feel you have no power to the ign switch and if by chance you do have power to it it is not going thru it
