Anonymous-0
seems like my 800 is loosing hydro fluid into the tranny ,,is that possible ???was runnin at Dad s hillside farm pullinthe drill up and down hills ...the pump pressure became erratic and it was good for awhile ,after,added fluid,,when I would loose pressureif I simply pointed the nose up a steep hill she would pik riteup and pull with moderate pressure ,,.going downhill I would loose all pressure ..,,I disconnected the cooling line before clutch spool and pumped about a gallon of fluid .. then drained about a quart from the drain plug ,, Where in the world did all the oil Go ???,,.Surely did not leak it ,,my 800 hasa few leaks but nuthin that serious...Gonna pull filter tomorrow to check condition ..btw ,,the 8 speed tranny is over full ..
