Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: case 970 brakes left works great none on right
05-09-2013 05:27:42
ok i bled them out that worked but still no ppressure on brake pedal, where should i look know, is the master cylinder serviceable?
05-09-2013 11:01:48
 Re: case 970 brakes left works great none on right in reply to cbrown, 05-09-2013 05:27:42
If you are sure all air is removed and the brake does not work with repeated pedal pressure look under the dash and grab on the linkage that connects the pedal to the master cylinder. Try moving the linkage up and down and compare movement of that brake with the one that works. There's a plastic joint that connects the pedal link to the link coming out of the valve. If that becomes disconnected the pedal never builds resistance because you are not moving the cylinder inside the valve.
