TractorLinks.com
Show Parts for Model:
Re: VA Hand Crank
Christopher Mikesell
05-08-2013 22:11:27
I simply used a large open-end wrench to set the timing on my 1953 VAC-14. I did so by turning the crankshaft using the pulley retaining nut on the front end of the crankshaft. First I used a large crescent wrench, but I later tried a large open-ended wrench.
I think that the size of the open ended wrench was 1 7/16" (I can check later). I happened to have the right size wrench to use on the 90 degree gear box on a gravely mower deck. It might be a good idea to order this wrench, since several of the large nuts on the late-series VACs use this size (including the nuts that retain the rear axels, and the nuts that hold the steering arms onto the steering shafts).
