Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: case 970 brakes left works great none on right
DKase
05-08-2013 18:48:41
With the engine running at an idle open the bleeder screw and wait for a steady stream of oil with no bubbles. There should be a static pressure to slowly push the oil through.
cbrown
05-09-2013 05:27:42
 Re: case 970 brakes left works great none on right in reply to DKase, 05-08-2013 18:48:41
ok i bled them out that worked but still no ppressure on brake pedal, where should i look know, is the master cylinder serviceable?
1370rod
05-09-2013 11:01:48
 Re: case 970 brakes left works great none on right in reply to cbrown, 05-09-2013 05:27:42
If you are sure all air is removed and the brake does not work with repeated pedal pressure look under the dash and grab on the linkage that connects the pedal to the master cylinder. Try moving the linkage up and down and compare movement of that brake with the one that works. There's a plastic joint that connects the pedal link to the link coming out of the valve. If that becomes disconnected the pedal never builds resistance because you are not moving the cylinder inside the valve.
