TractorLinks.com
Show Parts for Model:
Re: 1570 pto
1370rod
05-07-2013 19:54:51
If that mower wants to flywheel(Keep spinning) after shutting off pto and does not have a overrunning clutch, you will want to have the engine running as slow as possible before shutting off PTO. The 1570 has a brake that is applied with hydraulic press and try's to stop the shaft very quickly. If something keeps turning the shaft after PTO shutdown it is very hard on the brake and drum that the brake pad wears on.
111
05-07-2013 20:16:15
 Re: 1570 pto in reply to 1370rod, 05-07-2013 19:54:51
Thanks Rod.
I usually just pull the lever back far enough to interupt the power and let it freewheel and come to a stop, if I push the lever all the way to the off position it applies the brake. I figured it was easier on the pto brake doing this, just wondered what you think about this. Can it hurt anything in the pto?
Thanks Ben
1370rod
05-07-2013 20:48:30
 Re: 1570 pto in reply to 111, 05-07-2013 20:16:15
Sounds to me that should be fine, just keep the rpm's as slow as possible for shutdown. Rod.
