TractorLinks.com
Show Parts for Model:
Re: Case 870 hydraulic and shifting problems
mEl
05-07-2013 04:44:53
Rereading your original post, The one thing you could check that would cause these symptoms is a cut oring on the feed tube at the inlet port of the hydraulic pump, it's an easy task and if air is entering the hydraulic supply it most definately can be there. If you find a cut o ring, dress the edge of the suction pipe till it has a small radius to allow it to enter the oring without cutting it. I do that on every pump replace.
mEl
