Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Case 870 hydraulic and shifting problems
John Saeli
05-06-2013 12:55:17
Curious as to what oil you used that disolved the glue holding the fiber on. All the major brand oils say they are compatible w/ CASE-IH, but contributors to this forum have had other experience.
brokengun
05-07-2013 00:04:12
 Re: Case 870 hydraulic and shifting problems in reply to John Saeli, 05-06-2013 12:55:17
Marathon 577 was the oil i used. It eat the glue right out from under the plates the fiber disk peeled like the skin on an onion.
The C4 plate fiber disk was very close to like new thickness when they failed.
In the end I split that tractor 4 times before i got everything fixed. Every disk except the TLC failed.
The only reason the TLC didnt fail was because the guy that owned the tractor before me put a NEW case rebuilt engine and a new TLC at the same time
mEl
05-06-2013 14:46:52
John Saeli said: (quoted from post at 12:55:17 05/06/13) Curious as to what oil you used that disolved the glue holding the fiber on. All the major brand oils say they are compatible w/ CASE-IH, but contributors to this forum have had other experience.
The 870 has external dry brakes, no diff lock and unless someone has had it apart and put new C4 stuff in it should have all sintered brass clutch plates in it. I'm not saying that could not have been done but all 70 series of that vintage had sintered brass plates, including the large C4 plate, not till much later was the gray fibre plates used and I'm not sure the others were ever subed to the early tractors, the fact that the failure is heat related leads me to believe you have pump wear. Pay a competent shop to perform a flo test on the system, with one hookup right at the remotes the entire system can be diagnosed including the power shift clutch leakage. Anything else is speculation. . mEl
This post was edited by mEl at 14:48:11 05/06/13.
