Anonymous-0
I have a 930 comfort king and am cannot figure out this pto issue. I overhauled the pto and put it back together and I absolutely cannot get that engagement lever to snap over center. I know its put together right and the ive tried moving the end part of the lever with the splines to a different part of the shaft and I know its in the right spot now. Theres not much slop in the parts down there either. I am about at my wits end ive screwed around for hours with it. I'm not a total dummy either. I've also been adjusting the clutch back and forth to no avail. Maybe ive adjusted the clutch too far and the threads ran out on that clutch pack and I gotta pull the housing again but no matter where its adjusted to it still wont go. Also i can turn the output shaft freely and brake works and if i pull up on lever and hold with vice grips it will lock up good like it is supposed to. Sorry for being a little longwinded and if i repeated myself a few times but just really frustrated right now. Thank you so much. I hope this makes sense!
