TractorLinks.com
Show Parts for Model:
Re: please help
Mopar66701
05-05-2013 11:35:59
You dont have the lever indexed in the proper location on the splined shaft. Probably just one off. Thats all it takes
Caseanymous
05-05-2013 11:47:09
 Re: please help in reply to Mopar66701, 05-05-2013 11:35:59
Good thought but if I mov it one spline one way it's too far either way its like it needs to be in between two splines. I assume the lever snapping over enter is what holds it right? Or is it inside that holds it ? I'll try what hike more says but hell maybe ill cut a notch in the lever to hold it against the floor panel when it's up enough to hold clutch tight?
Mopar66701
05-05-2013 11:58:18
 Re: please help in reply to Caseanymous, 05-05-2013 11:47:09
Going to have to get it to go overcenter to hold. Im speaking from recent experience as i just did one of these and it acted like yours. I thought i lined up my splines right and i even marked it before disassbly but as you know its not easy to see where thats located. Assuming you did put things together right inside it comes down to the lever being correctly indexed on the shaft and then proper adjustment of tge clutch pack. Wish i had someone to turn the engine when i was doing mine. I bet i was back and forth 50 times. I was off one spline
mEl
05-05-2013 13:59:07
 Re: please help in reply to Mopar66701, 05-05-2013 11:58:18
Mopar66701 said: (quoted from post at 11:58:18 05/05/13) Going to have to get it to go overcenter to hold. Im speaking from recent experience as i just did one of these and it acted like yours. I thought i lined up my splines right and i even marked it before disassbly but as you know its not easy to see where thats located. Assuming you did put things together right inside it comes down to the lever being correctly indexed on the shaft and then proper adjustment of tge clutch pack. Wish i had someone to turn the engine when i was doing mine. I bet i was back and forth 50 times. I was off one spline
You cannot forcibly hold the PTO pressure on manually externally or the brass engagement yoke will be destroyed very quickly. It is meant to engage and disengage the clutch and the little internal links dropping over center is what locks it up from disengaging.
Look in the hole while someone holds the lever up and observe the links, if they are not going overcenter the clutch adj is to tight, if they are it is to loose, study it for a couple minutes and you will see what I mean. The engagement shaft and its lever should have centerpunch marks to locate the proper splines together.
Keep working at it, you'll get it providing the proper amounts of parts are installed.
mEl
This post was edited by mEl at 14:00:17 05/05/13.
Case Nutty 1660
05-05-2013 15:54:09
 Re: please help in reply to mEl, 05-05-2013 13:59:07
just a thought but you are putting the cover back on each time you test for engaugment?
Mopar66701
05-05-2013 14:29:46
Dont suppose he might have left a plate in when he took it apart possibly?
mEl
05-05-2013 15:19:52
 Re: please help in reply to Mopar66701, 05-05-2013 14:29:46
Suppose it's possible but should have seen that upon reassembly, that clutch can be adjusted within a few clicks on the bench requiring very little adjustment in the tractor, I adjust them so they will just snap overcenter with real firm hand pressure then install them and a couple clicks and you're there.
Done many many in a lifetime tho.
mEl
