case 680 ck b
Fuzzeone 2
New User
I removed the shuttle shift box from tractor, to replace front pump and torque convertor. was able to remove fairly easy , but now cant get get it back in chassis. any one have a easy way other than pullen out the engine ??? trhanks much
I have done many of those and never pulled the engine, the tranny must be square with the bell housing and the internal pump lugs must be positioned so the converter drive lugs can engage without interference. once it is so the lugs can engage, slight rocking may be necessary to get the splines in the converter to line up.
mEl
