830 w/336 turbo
Case8940
I"m looking at a 830 that has been made into a 5500# Puller.
Has a 336 with a 3LM turbo, bigger injectors, and modified
pump. I believe the motor came out of a W14 wheel loader.
The motor has been rebuilt and balanced, internal balancer
removed. I was wondering how many cubic inches were
possible with the motor, without major stroke work and how
much power is possible? Does anyone have any experience
with pulling these 4 cylinders that could offer me some
advice? I will be pulling in a 3000 rpm, 2.33 inch inducer
bore turbo class.
Are you looking at the one that is on pull off? If so i built it and pulled it for a couple years before i sold it to the guy who has it listed. Either way i have built one that ran 7th gear at 6000lbs with ease. Thad
Do you have an open email? Would you be open to talking about the tractor and what all you did to it. I would give you a call tomorrow if you would not mind. Thanks
