Case 2020 rear lights don't work.
Anonymous-0
The rear red lights work and the flashers on top of the cab work, but I cannot get the field lights to work on the rear. Front lights, both up front and those bolted on the front bottom of the cab work. Does anyone know what wires the back field lights would be on the bottom left side of the cab? I believe there are two or three connectors there. Do the wires run clear up to the top of the cab and can they be seen under the cover on top?? Does anyone have a wiring diagram that could be posted? Any help would be appreciated. Thank you.
