Anonymous-0
The hub lugs are moving on the rim about 1/2 in each direction on my right wheel. I don't know if tightening the nuts will work anymore. I think I have done that once or twice. Looks to me like the "lugs" on the rim and/or the "lugs" on the cast hub are worn. Which seems to get worn more or do both? I do have 4 more of the "lugs" on the rim I could move the "lugs" on the cast hub to by loosening everything up and rotating the hub. Will it tighten up if I move to the other four spots on the rim? Also, what if I use 4 hub "lugs" that are not being used now - will that help? Is there such a thing that the 8 or so lugs are all worn enough length wise that I need to go to a junk yard and get 8 different ones? Any other ideas??? Thank you.
