Case 1030 Hydraulics
rschafer75
New User
We have a case 1030 with a front end loader. The inside lever of the axillary valve (which is connected to the bucket) leaks off. I have went through the aux. valve and replaced o-rings and gaskets but it didn't help. Did I miss something, or are there some adjustments I don't know about, or could the cylinders leaking? Can anyone give me some advice?
You need to eliminate where the problem isnt. Swap hoses to
the other valve and/or lift a foot or so and disconnect hoses to
see if it still drops. See how we are narrowing down and taking
out possibilities? Once you can say where the problem isnt
you know better where it is. Then might be able to help you
better
