3point leveling arm case 300
lil bull
New User
The arm that is adjustable on the 3 point is frozen in place. I recently got a scraper blade and tried to adjust the arms to make it level, no go. I tried pr blaster and using a pipe wrench on the threaded shaft to get it to turn and it will move up or down on the treads. Is this a common issue. I have never had to adjust this before so it has een years since it was ever moved. Any suggestions as how to free it up with out tearing it up would be most greatly appreciated.
Heat..........and lots of it. Remove it from the tractor, clamp in a solid vice and then heat the top 3 or 4" of the outer housing. Then be ready with that pipe wrench and a cheater bar. Tough on the paint but it will free up!!
