TractorLinks.com
Show Parts for Model:
Re: That 1930 Case L - still not running
cs.hess
04-22-2013 17:23:45
Magneto spark should jump almost i/2 inch if held that far away from engine block. It should be blue spark. If it is only yellow it is weak.Also i would turn off gasoline supply --remove plugs an check gap-have them dry an than crank tractor couple turns to clear out old gas .Than turn on gas-pull choke an pull through until each piston has fired an than open chokee halfway an you should get it startsd.Pulling would be good idea.That would keep you from getting arm broken as while i have cranked sc an dc many times i sure dont think a kickback on crank ow a l would be very healthy for arms!!
