rusty6
I mentioned over on the combine board about installing the cab on my 930 Case. Here is a photo taken March 29, 1978. Installing the new "Cozy Cab". One of the best after market cabs you could buy at the time. It added quite a bit of weight so I decided to remove the huge cast weights that a previous owner had installed. I figured the cab plus the fluid in the tires might be enough weight but that 930 really needed more than 18.4x34s for good traction .
(quoted from post at 10:09:22 04/21/13) Very nice picture. Those Cozy cabs were a step up from the older 3 cornered ones.
Around here "Fibro" the cab with the fibre glass top was one of the most popular add on cabs. Cheap and built right locally. They were better than nothing but no insulation for soundproofing. I remember working for a neighbour with a new 830 Case and Fibro cab about 42 years ago this spring. I thought I was in the big league then. :)
