loader on 94 series tractors
Anonymous-0
I have a 2094 and 2394 I would like to put mounts for Westendorf TA-46 loader. Does anyone have a neat way to move the muffler without blocking the left window and still not risk getting burned as you enter or exit the cab? How about a muffler like the MX-120?
DU-AL had a muffler that stayed in the same location on the 2094, I had one on my 2090, it looked like the bullet muffler on a 1070 or a 9600 Ford
Case also had one referred to as a "fire burner" exhaust that moved the muffler under the tractor under the torque limiter or clutch housing. I had a 2290 with a case 90 loader that had that on it.
Kevin
The 2094 you should be able to turn the exh. manifold over so the muffler bolts right on the manifold except it is twords the cab more. On the 2394 you will have to get some flex pipe and probably run a straight pipe for visibility.
